Geolocation keyboard shortcuts
Roman
Post by Roman »
Have keyboard shortcuts been allocated to copy the geolocation data (ideally just the latitude and longitude) from one image, and then paste it to another?
Re: Geolocation keyboard shortcuts
There are no keyboard shortcuts to copy coordinates in the GEO Panel. You can use the copy/paste buttons.
Tip 1, Keyboard Shortcuts are described in the "Keyboard Shortcut Reference" manual. Find it in the ? icon of the left sidebar.
Tip 2, note the marker in the lower right corner of the Copy button. That indicates that you can "click-and-hold" the button for additional options.
Roman
Post by Roman »
Thanks Hert, that is the method I have been using. I was hoping that there might be keyboard shortcuts similar to the ones used for copying and pasting labels.
