How do I view lable geolocation on the map?
Roman
Post by Roman »
I can't see how you display the location of a label's assigned latitude and longitude on the map. There are buttons to do lookups but not one to simply show the currently assigned latitude and longitude on the map. The "Select from map" button displays the last used latitude and longitude not the ones assigned to the currently selected label. Is there a way of doing this?
Regards
Roman
Re: How do I view lable geolocation on the map?
As soon as you select the image if it has Lat & Long in the exif data then a green pin will appear on the map showing the location of the image.
location green pin.jpg (456.74 KiB) Viewed 292 times
Roman
Post by Roman »
Thanks Geoff but that is not what I am after. If you right click on a geotagged label and display its details there does not appear to be a way of viewing the assigned latitude and longitude on the map.
Regards,
Roman
If you right click a Label, then select Details, open the Geo Location panel at the bottom, then the clicking the Lower Right icon will open the map with the location of the Label shown ?
label location.jpg (490.76 KiB) Viewed 287 times
Roman
Post by Roman »
That does not appear to work for me Geoff. Can you please try this test:
1. Create a new label and assign a geolocation to it.
2. Select an existing label that already has a different geolocation assigned to it.
3. Right click and select details.
4. Select the bottom right icon.
For me the geolocation of the first label is displayed, not the second label's.
Please let me know if you get the same result.
Roman
Yes I can confirm that the previous location appears on the map, rather than the current one opened!
Tried several things but it remains displaying the previous location rather than the currently opened label.
Roman
Post by Roman »
Thanks Geoff, it is good to know that the problem can be reproduced by someone else.
Not sure the latest update has worked Hert, I've updated the Mantis report and included a youtube of the problems I'm seeing.
Roman
Post by Roman »
Thank you for creating a bug report in Mantis.
Seems cured with version 4624.
Roman
Post by Roman »
I just installed version 4624 and can confirm that the issue appears to have been resolved.
