Search for images not matching a label
jack208
Post by jack208 »
Say I've a bunch of images in my catalog.... and I've a "Year" label to tag which year they were taken.
Assuming this is what I see
YEAR 211
- 2021 21
- 2022 190
But I've total of say 221 images. So this means 10 of them are not tagged with any year. I would like to search for these 10 and then apply the YEAR tag to them.
I tried typing this in the Search Bar "-2022" but it pulled up all 2022 images for me.
Can the "-" exclusion search work on its own? The example in the manual was for "Jane-John" ie search for "Jane" without "John". But mine was just search for "not 2022".
TQ
Re: Search for images not matching a label
A warm welcome to the forum.
Drag 2021 to Dynamic Search
Right click on it and set it as "exclude"
Do the same for 2022
Then run the search
BTW; consider using the Timeline instead of using Catalog Labels to tag years.
