Seeking easy way to Verify Folder - Scan for Missing Files
marklevine
Post by marklevine »
Hi all,
I frequently aim my mouse at a folder, click right, and choose Scan for Missing Files. Is there a programmatic way to do this? I cannot find a place to assign a keyword shortcut to a frequently used function. Is there another way to initial a scan to verify folders? I do this so often...
This is a particular problem when I am viewing all images for a keyword. When I want to edit one of the images and add newly created versions to the catalog, I must first Show More from the folder containing the thumbnail so I have a folder name where I can right mouse to execute the scan. I really want to stay in the keyword tab without Showing More, and initial a Scan for Missing Files in the folder that contains the current thumbnail.
Thanks in advance,
Mark
Re: Seeking easy way to Verify Folder - Scan for Missing Files
Right click on a thumb and select Operations-Verify Folfers for Files
marklevine
Perfect. Thanks, Hert. I've tested it from a tab showing images tagged by keyword and it works perfectly.
