Duplicate areas ?
Duplicate areas ?
Has anyone found a way to identify images with duplicate areas (linked or otherwise) ?
I have the situation where originally I was adding areas by hand, then started to use other products to identify faces and hence now have a lot of images with duplicated areas;
In the example above I have slightly offset the duplicate so it can be easily seen, before deleting it! Often its very difficult to identify a second label or area where they totally overlay each other.
Otherwise could a script be written to list Areas with identical names / labels within the same image along with a count of the number of duplicates ?
Re: Duplicate areas ?
In the next build you will be able to use a Filter Script for this (you need build 4521 or higher).
Many thanks Hert, it will be much appreciated!
Thank you! Working nicely :-)
