Not quite sure where this appears or its function ?
"Build 4494; In the Catalog Label Details->GEO Details you can now enter a custom text for forward lookup"
I can't seem to see anything that looks like a "forward lookup" field, but I might be looking in the wrong place ?
[edit Hert; changed the topic title to better match the content]
New feature in build 4494: Catalog Label Details->GEO Details >Forward lookup
Re: New release / New feature ?
Re: New feature in build 4494: Catalog Label Details->GEO Details >Forward lookup
Ah thank you, understand now!
On a related aspect would it be possible on a Reverse Lookup from the Geo Panel, to handle multiple images as opposed to only a single selected image, rather than having to right click|Operations|Geo Reverse lookup, the same/similar warning panel could pop up to indicate that you are handling X images as a warning ? I suspect all of our work flows differ but I generally end up "looking up" an entire shoot in one go and hence use a Ctrl-A to select all images and then it would be nice to hit the single button and get all the images handled on one go.
- agreed, I've always thought the current behaviour unintuitive, though since, as you say, the possibility exists from the right click menu I've never thought of it as a big issue. But if anything the right-click option should act on a single image and the panel option act on all selected images IMO.Reverse Lookup from the Geo Panel, to handle multiple images
It got mentioned in this thread a few years back viewtopic.php?t=24180.
