Any workarounds to install PS v7 Server Edition if getting Access Violation on first run?
yogavidyapubs
Post by yogavidyapubs »
I'm getting an access violation on first run on PS v7 Server Edition, PostgreSQL 12 or 14 on Windows x64. It shows the yellow progress bar then gives an error stating which step it got until.
I've tried uninstalling and reinstalling everything a few time and on different versions of Postgres (12 & 14). Running v7 on a working v5 givse the same error and then leaves the previous instance unusable as the database was started an upgrade and 5.3 will not work with it.
Any ideas? I reported an issue here: https://mantis.idimager.com/view.php?id=3492
This is the build I was able to get from the website via the trial email:
Build 7.3.0.4409
62,216KB
PSv7 failling to upgrade databse on PG 12 and 14 - unable to open PSv5.PNG (16.67 KiB) Viewed 168 times
PSv7 failling to upgrade databse on PG 12 and 14.PNG (47.27 KiB) Viewed 168 times
Re: Any workarounds to install PS v7 Server Edition if getting Access Violation on first run?
I have sent you an email.
yogavidyapubs
Downloading v7.3.0.4494, as suggested by Hert, resolved the issue
