Dop-Sidecars
BertiIrmo
Dop-Sidecars
Post by BertiIrmo »
I've been moving my RAW files from one folder to another with PSU a lot lately to make reading in the new RAW files faster with PhotoLab 4.
Problem: I have now noticed that the dop files (e.g. DSC_1488.NEF.dop) are not moved. A test showed that they are also not deleted before the move with PSU when the RAW file is deleted.
What do I have to set for this?
(PSU build 4421)
Thanks for the help.
Friedrich
bimo
Re: Dop-Sidecars
Post by bimo »
Same here :(
BertiIrmo
Re: Dop-Sidecars
Post by BertiIrmo »
with the build 4428 the dop files are recognized and deleted together with the NEF file, unfortunately not the whole version set (syntax error).
Friedrich
Re: Dop-Sidecars
Please update to 4430.
BertiIrmo
Re: Dop-Sidecars
Post by BertiIrmo »
thank you Hert, now everything is back in order.
AlainB
Re: Dop-Sidecars
Post by AlainB »
I have a related problem: if I delete a version set made of
a NEF file. XXX.NEF
a dop file XXX.NEF.dop
a xmp PSu sidecar XXX.xmp
The dop file is not deleted
I have the latest macOS PSU
AlainB
Re: Dop-Sidecars
Post by AlainB »
AlainB wrote: 18 Jul 22 10:44 I have a related problem: if I delete a version set made of
a NEF file. XXX.NEF
Problem solved with 7.3.0. "Check for update" mislead me into believing that I had the latest PhotoSupreme version.
