Cascading stacks
germie
Cascading stacks
Post by germie »
Hi all,
I ran into the following problem:
- I create a stack in 7.2.0.4414 and assign keywords and rating to one of the stacked files. Say x.nrw. The other file in the stack is x.jpg.
- Now I go to the stack menu of x.nrw and hit "cascade thisd item's metadata to full stack"
- In the following window I select "Cascade image details" and "Cascade Ratings" and hit OK
- then it shows me a dialog "Select Items to cascade to" and below that: path\x.nrw (that should be path\x.jpg I think)
- When I hit either OK or yes to all it returns a dialog "No items selected" and nothing gets cascaded.
Am I doing something wrong here?
Kind regards from Holland
Germ Wind
germie
Re: Cascading stacks
Post by germie »
Hi all,
I just noticed, my download from the control panel (server PostgreSQL) is still at 4414 right now. The server version for SQL server is at 4421. Is that intended to be so?
Any help is greatly appreciated.
Germ Wind
That is correct.
There is no build 4421 for PostgreSQL
germie
Post by germie »
Thanks Hert for the quick response. I sent you a message about the cascading stack issue.
Germ Wind
germie
Post by germie »
Thanks Hert for the latest update. Cascading stacks works well now.
Am I me or is the performance of 4428 snappier than 4414?
Germ Wind
Thanks for the feedback. The latest build should indeed be snappier
