With the increasing use of metadata to record & display Regions/Areas within images I have recently started to identify problems where various imaging packages have created a plethora of Regions/Areas on an image using the various differing standards (MWG-RS:Region List, IPTC Extensions:Image Regions, MP:Regions, Area Tags etc) along with probable software bugs where multiple different overlapping regions for the same object, incorrect orientation flags causing misplacing of regions etc.
Whilst on-screen representation of the areas and the related data is essential where there are overlapping areas or off-screen / edge conditions or duplicated identical areas present the on-screen presentation of the areas have problems. In these situations a tabular presentation of the areas is essential, allowing the duplicated information to be more readily spotted and/or located where off image & edge conditions prevail. An example is the image below, where differing packages have created identical areas but with incorrect orientation information also other viewers which seem to have a mind of there own as to orientation for the areas! This example was chosen for simplicity and doesn't show any multiple identical placed areas which can be a a significant problem to identify from image information alone!
To this end can I propose that an additional view be available for the tabular display of all Region/Area data within an image in conjunction with the visible image itself, this could be an overlay on the current Preview screen or a separate righthand pane where the data can be displayed and edited (Create/Edit/Delete functions) as well as or in conjunction with the Preview display.
Use of the existing views are limited;
Details righthand pane - is complicated by the way that the textual information is distributed throughout the metadata sections and its duplication in differing sections which causes additional problems when trying to delete data as it is repeated in other metadata sections!
Custom Info view - is difficult to use due to formatting of long lines and field separators.
Grid view - is again limited due to field lengths
So am I alone in looking at these problems ? Do others on here have similar problems ? Have you found other ways of tackling it ?
I've created a Mantis report as per the first line of this posting .....
Any thoughts on the subject
