Labels > AI > Detect Labels API error
I have the GEO API working ref. viewtopic.php?t=29969 and the Cloud Vision API is added/ enabled however I get the following message box when I click Detect Labels from the LAP:
I'm using the latest EXE 7.1.0.4306. I've gone through the latest versions of the manuals for 1) Setup Google API key 2) Artificial Intelligence without success. Thanks for any help.
Re: Labels > AI > Detect Labels API error
Check if your API restriction is still valid, if there’s an IP restriction and your IP has changed then the API will fail
Check that your payment method in the Google account is still valid
If you still cannot get it to work then contact Google. They should be able to tell you why their API generates this message for you. Google typically responds fast.
Thanks Hert - would you expect the PSu GEO mapping functionality to be still be working if the IP restriction settings were wrong though? I doubt this is an issue. Address from https://whatsmyip.idimager.com hasn't changed since I 1st set everything up last year.
Does the Google Cloud (free) account expire i.e. no longer free after some period? It's not important enough to me that I want to pay Google for the service.
The Google Cloud Platform dashboard says "all services normal". Although I can understand the requirement, it's complicated when part of a products functionality is provided by a 3rd party, as to who is responsible when an issue like this arises. The Google "dashboard" is a bit overwhelming in where to even go to check settings.
any suggestion where?
Google runs the Google Vision service. PSU doesn't have any access to the Google's backend. There is no way for anyone (PSU included) to know how an API is configured at Google.andrew.heard wrote: ↑22 May 22 4:40 Thanks Hert - would you expect the PSu GEO mapping functionality to be still be working if the IP restriction settings were wrong though? I doubt this is an issue. Address from https://whatsmyip.idimager.com hasn't changed since I 1st set everything up last year.
If up to now you were using the Google One Year (I believe) trial account and that has now expired then that explains why your API no longer works. You have to visit the Billing section in the Google account first to accept the continuation of your use.Does the Google Cloud (free) account expire i.e. no longer free after some period? It's not important enough to me that I want to pay Google for the service.
From the PSU Setup Google PI manual:
As stated there, Google Vision comes with free monthly bundles. In addition, if you want to control the Google cost then setup a Budget limit in your Google account. Visit the API console, then click the upper left hamburger menu, then select Billing. In Billing, select "Budgets & alerts" and create a new budget there to control your costs or even prevent any costs outside of the free bundle.Google Vision is not free to use, but it
comes with a monthly free bundle to make it cost free for average home use. For more
information about Google Vision’s pricing, you can check this page:
https://cloud.google.com/vision/pricing.
Photo Supreme caches Google Vision results to prevent unnecessary API calls or optional API
costs.
Thanks for all your help Hert. I may just delete the existing account & start from scratch, when I get a chance. It still seems odd that part of the API is working - GEO whereas another part of the API is not - Detect Labels. But no need for reply/ comment.
