Should I use the Light Table instead of the Image Basket?
barneagle
Post by barneagle »
Up to now I have used Image Basket to compare similar images. This allows me to switch easily between a small selection of images, view them full screen, apply ratings, etc. and then, after emptying the basket, get back quickly to where I was in the main screen. However, after a recent update I'm no longer finding it so easy to get back to where I was before I opened the Image Basket. When I close the Image Basket I'm taken to the beginning of the current selection of thumbnails. There used to be a key press (I can't remember what it was, perhaps an arrow key) which would take me back to the correct place. Now, unless I'm missing something, I have to scroll through the whole section to find it.
So, I wonder whether there is a better way of comparing small selections. Could the Light Table be what I want? How does the Light Table work? The only Help I can find is the list of relevant keyboard shortcuts.
