Reverse GEO no longer working
fabrizio.giudici
Post by fabrizio.giudici »
Hello. It seems that Reverse GEO is no longer working - it used to since a few time ago.
Basically, while State/Province, Country Code and Country do work (demonstrating that there is no problem with the API access), Location and City are always empty.
For instance: 44.498398,8.864669 - if I go to https://developers.google.com/maps/docu ... ng-reverse and enter these coordinates, I correctly get "Percorso verde ex Guidovia, 16014 Ceranesi GE, Italia". Inside PhotoSupreme Location and City are empty.
Photo Supreme + Capture One
http://stoppingdown.net
Re: Reverse GEO no longer working
Check your geo settings perhaps ?
fabrizio.giudici
First, forgive me for the late feedback - I'm in the middle of a sort of burnout since several weeks, so I'm starting activities and forget to close them.
For what concerns your proposed solution... it's already set as you suggest. In fact some geotagging operations are correct up to the location level (this detail wasn't actually clear in my original post).
I do find that even City level doesn't always come back from Google correctly at all times it varies with just the 5th 6th decimal level of the Lat/Long !!
fabrizio.giudici
I have upgraded to version 7 and now the feature seems to work fine - at least it did with my latest sessions. I'll try to overwrite previous unsatisfactory geo data.
fabrizio.giudici
I can confirm that version 7 gives great improvements in geotagging for me, but there is still some issue. Since it's different in nature, I think it makes sense to create a new post.
viewtopic.php?p=129788#p129788
