I hope this proves to be useful for a possible reason for some unexplained crashes.
I couldn't work out why opening an imported folder with just 6 jpeg images kept crashing PSU.
So I created another folder with the same images and then drag and dropped one at a time into PSU - Bingo -found the guilty jpeg.
Turns out it had corrupted Exif data - initially I thought it was just the Date / Time field see here:
Model: COGLpMX P610 - that looks like corruption of CoolPix
Software:
Date/Time: #0‹ÝÉ” that is definitely not right
However when I used XnView MP's Exiftool below is what I found.
Once I opened and did a SaveAs in PShop it cleaned up all the exif and the problem went away.
ExifTool Version Number 12.25
Warning Bad offset for IFD0 ImageDescription
Warning Bad format (4098) for IFD0 entry 1
Warning Bad format (1059) for IFD0 entry 3
Warning Invalid size (2147483656) for IFD0 tag 0x011b YResolution
Warning Bad offset for IFD0 tag 0x012a
Warning Bad offset for IFD0 Software
Warning Bad offset for IFD0 YCbCrPositioning
Warning Bad format (389) for ExifIFD entry 0
Warning Invalid size (2147491848) for IFD1 tag 0x011a XResolution
File
Directory D:/xxxxxxxxxxxxxxxxx
File Size 3.4 MiB
File Modification Date/Time 2016:02:22 13:48:29+11:00
File Access Date/Time 2021:10:02 12:36:38+10:00
File Creation Date/Time 2021:10:02 12:11:35+10:00
File Permissions -rw-rw-rw-
File Type JPEG
File Type Extension jpg
MIME Type image/jpeg
Exif Byte Order Little-endian (Intel, II)
Image Width 4608
Image Height 3456
Encoding Process Baseline DCT, Huffman coding
Bits Per Sample 8
Color Components 3
Y Cb Cr Sub Sampling YCbCr4:2:2 (2 1)
EXIF
Camera Model Name COGLpMX P610
X Resolution 0.0001430510792
Modify Date .016:01:11 11:02:32
Compression JPEG (old-style)
Y Resolution 0.2043734599
Thumbnail Offset 13568
Thumbnail Length 5608
Thumbnail Image (Binary data 5608 bytes, use -b option to extract)
Composite
Image Size 4608x3456
Megapixels 15.9
Invalid / corrupted Exif info crashes PSU
Brian
Melbourne Australia
V6 PSU, Win 10-64, Canon 1Dx, 50D, FUJI X-T1, X-T2, LR CC, PS CC2020
Melbourne Australia
