exiftool need to remove some values, need command line ,please help
mantras
Post by mantras »
Hi
about exiftool , i have downloaded the last version
may i know the command line to remove these entries
for example i would like to remove these
IPTC
DocumentNotes
in short I would like to remove the entries DocumentNotes (it's a tag of IPTC )
windows 10
thanks
Re: exiftool need to remove some values, need command line ,please help
Then in Exiftool it should be
-iptc:DocumentNotes=
mantras
Post by mantras »
Mke wrote: 28 Jul 21 23:21 Then in Exiftool it should be
hi
sadly the gui is no more update
it works ! But i have to use cmd or powershell would like to use with photo supreme
thanks Mike
