Flickr Uploads Failing
n8vz
Post by n8vz » 20 Jul 21 18:16
I've been trying to upload about a dozen photos to Flickr using PSU's sharing option. Each time it gets to exactly 64.7 percent of the last process and freezes. I've done a reauthorization with Flickr, but that didn't help. None of the files is corrupt. I can't figure out what is going on. Any help would be appreciated. Thanks. -- Carl
Re: Flickr Uploads Failing
Post by snowman1 » 20 Jul 21 22:42
I would recommend to share to a folder and then use Flickr's own uploader (web page) by simply selecting all the files in the folder and dragging them to the uploader web page. It's a robust and easy method.
Snowman1
