Question re Versions
Larry56
Post by Larry56 » 11 Jul 21 19:25
I use folders based on year/month and haven't used version option because when going to a folder I'd still see both the raw and the jpg versions two thumbnails. I was playing around with versions again and still see each displayed. I've looked at settings but don't see an option to only display a single version set in folder. Have I missed something or is there still no way to display only a singe version set?
Re: Question re Versions
Post by Mke » 12 Jul 21 0:55
There are 3 ways you can do it:
- apply a filter to the folder to only select JPG or RAW images
- stack the images (which you can do as well as, or instead of, versioning)
- change your preferences to always show versions as a set:
Or split the JPGs and RAW files into different folders.
Larry56
Post by Larry56 » 12 Jul 21 6:32
Thank you. Somehow missed the Always together as a Set.
