creating new sub folder, new folder doesn't appear
jd
Post by jd » 17 May 21 0:51
PS6: in Folders view, if you create a new subfolder (via the context menu) in a directory that doesn't have any subfolders, the new subfolder doesn't display.
the solution i've found is to collapse and expand the "top level folder", then re-navigate to the place where the subfolder was created.
HCS
Re: creating new sub folder, new folder doesn't appear
Post by HCS » 21 May 21 8:45
Hi, i see that behaviour as well.
I don't worry too much and close the folder, wait a few seconds and then open the folder to see the new sub folder.
If it bothers you much, you could create a support ticket in Mantis.
