Restore - Unable to create file
Bongo
Post by Bongo » 01 May 21 16:05
I wanted to test like backup and restore works. If it is necessary.
The restore comes this message:
I did a reboot before.
Regards, Bongo
Photo Supreme V6 Single User Edition, Windows 10.
Bongo
Re: Restore - Unable to create file
Post by Bongo » 04 May 21 8:54
Someone an idea? Actually, I regularly make a Zip file from the entire directory "IDIMAGER SYSTEMS, INC.ZIP". Except the thumbs dB.
Here is the command with 7zip:
"%programfiles%\7-Zip\7z.exe" u "-xr!*.thumbs.*" "IDimager Systems, Inc.zip" "C:\Users\Erich\AppData\Local\IDimager Systems, Inc"
I have not yet dared to make me a restore in this way. Would that work?
Regards, Bongo
Post by Hert » 04 May 21 11:36
A restore of the Single User edition is a simple file copy. So yes, you can close PSU and copy the cat.db file from the backup folder.
