Imported folder will not be displayed
siehorst
Post by siehorst » 24 Mar 21 21:47
new subfolder with pictures in my 2021 picture folder.
- scan for missing folder & files
- detecting the new folder
- say 'ok' to import this folder,
- progress is being displayed, but afterwards (after refresh) no new folder in the folder list
- closing and restart: no new folder in the list
- start scan for missing files & folder again
- detecting again this new folder but after
- no progress bar, and no new folder in the list
- compact database: no changing
the same result if I use the import dialog.
where is my new folder?
horst
siehorst
Re: Imported folder will not be displayed
Post by siehorst » 24 Mar 21 22:02
ok, I found the folder using the find function.
see the attached screenshot.
the new folder is '2021-03-21_24'
why ist the 2021 completely imported and doubled and not only the missing one to the correct position?
HCS
Post by HCS » 25 Mar 21 11:11
Did you perhaps change the disk (E:)? It seems that PSU thinks it is a different drive from the identification behind the drive number.
Perhaps Hert can help here.
siehorst
Post by siehorst » 25 Mar 21 11:16
Hi HCS,
no, it is the SSD in my laptop. you can see that the ID is the same.
When I have done so as described earlier, I got the expected result.
horst
Post by Hert » 25 Mar 21 11:24
The ID is the same, but the volume name is not the same.
Right click on the "wrong" top level E drive and select "Map to the Correct Physical Folder"
siehorst
Post by siehorst » 25 Mar 21 14:21
I get the message box:
'Mapped 0 folders'
regardless which one I choose.
And how can it be, that both 'E:/' are marked as
'Make this the Top Level Folder'?
Meanwhile the count of pictures is shown as '0' wheras the 'new' imorted folder shows the correct count but not the content.
As mentioned, this is a new behaviour.
siehorst
Post by siehorst » 25 Mar 21 21:53
Puuh, now after being offline for a while and a new start suddenly without further changings it seem to be a magic of selfhealing.
But good to know that there are some versions in the Backup.
horst
