Adjust icon selected when Adjust is activated
User avatar
OldRadioGuy
Post by OldRadioGuy » 16 Mar 21 3:10
In PSu build 6.0.0.3613 the Adjust icon displays its activation color when another function is actually selected. In the example attachment here, Details has been selected, but Adjust is shown activated.
PSu Details Error.jpg (118.5 KiB) Viewed 357 times
macOS 11.2.3
Photo Supreme 6; DxO PhotoLab; ON1 Photo RAW; ExposureX; Affinity Photo; PhotoLine; macOS Big Sur; 27-inch iMac, Retina 5K
Re: Adjust icon selected when Adjust is activated
Post by Hert » 16 Mar 21 10:16
PSU considers the "adjust" as one of the possible side panels. When you open an image in the editor by clicking "Adjust" then the editor is opened with the adjustment panel as the side panel. If you then click Details then the Details panel is opened in the side panel. But the editor is still open so Adjust will still be highlighted (as in your screenshot). Press Esc (or BkSp) to close the editor and "Details" will again be highlighted
