Custom Fields Not Decoded on Info Panel
gcorbin
Post by gcorbin » 14 Mar 21 22:35
I have added several custom fields
exif:Meteringmode
exif:ExposureMode
exif:ExposureBiasValue
which display perfectly in the Details panel in the “Your Custom Fields” section (numeric codes decoded to the description) but are not decoded on the Info panel.
Correctly Decoded in the Details Panel but Not Decoded on Info Panel
I am using 6.0.0.3613. This is a minor annoyance in an otherwise excellent upgrade. I love the speed improvements.
Re: Custom Fields Not Decoded on Info Panel
Post by Hert » 15 Mar 21 11:00
This will be fixed in the next build. Thank you for reporting
gcorbin
Post by gcorbin » 18 Mar 21 1:56
Thanks Hert. Works perfectly now.
