Copy and paste labels from images to label sets
Alfons
Post by Alfons » 10 Mar 21 11:15
Is it possible to copy labels from images and paste them to label sets in a similar fashion like copying labels from images/pasting to images using Alt+Shift+C/Alt+Shift+V? It would be very convenient to copy numerous labels to label sets in one go.
Re: Copy and paste labels from images to label sets
Post by Hert » 10 Mar 21 12:17
There's no paste option to paste to a Label Set (I like the idea).
Try this:
1. Select multiple Catalog Labels in the left side catalog tree
2. Right click on a selected label and select "Details"
3. In the drop down of the Label Set Memberships, tick the box for the Label Set that you'd like to assign all the selected labels to
Alfons
Post by Alfons » 10 Mar 21 13:09
Thanks for the fast reply.
You describe an option to add multiple labels from the Categories panel to Label Sets in one go. That's fine. This is not exactly what I want. Currently it is only possible to add single labels from an image to Label Sets (Right Click - Label Set Membership). It would be very convenient to be able to select multiple or all labels and add them to a Label Set.
