Zoom on mouse click lost in PSU 6 (compared to PSU 5)
tumirnix
Post by tumirnix » 07 Mar 21 23:08
I've recently upgraded PSU from version 5 to 6 and now I'm missing one feature. In the view of a single image it was possible to zoom (100%) when I click on a part of an image. In PSU I can only use the keys "Z", which shows the upper left corner in 100%, and then key "A" to see the full screen view again. To check the details (e.g. faces) which are not located in the upper left corner it's necessary to click Z and move the image to the interesting part.
Unfortunately this is much slower for checking image details, which are not in the upper left corner.
Would it be possible to re-activate the old behaviour?
Thanks in advance
Martin
Re: Zoom on mouse click lost in PSU 6 (compared to PSU 5)
Post by Hert » 08 Mar 21 8:18
You can hold down the Shift key and Click to get the "click to zoom" effect.
You can also enable "Click to Zoom" in the options of the Viewer. I recommend using the Shift+Click.
tumirnix
Post by tumirnix » 09 Mar 21 0:21
Thanks, Hert, for the quick and simple answer(s).
