using photo supreme with Affinity photo.
c76burgess
Post by c76burgess »
Hi all,
i'm brand new to photo supreme. I'm considering using it as my DAM alongside affinity photo. I'm able to send files from photo supreme over to affinity for editing but i cant work out how to save the edited file back into photo supreme. The edited file shows up next to the RAW file in the folder on my external hard drive, i just can't get photo supreme to recognise it. Any suggestions would be appreciated.
Re: using photo supreme with Affinity photo.
First of all a warm welcome! I changed your user name because it was an email address which is not to be used on a public forum.
After saving the edited file in Affinity, you can use the Verification in PSU to find the edited file. Try right click on the thumb and then Operations -> "Verify Folder for files". That will scan in the folder of the selected thumb(s) and for deleted, new, or edited files.
