Backups
johnbarrett
Backups
Post by johnbarrett » 31 Dec 20 11:39
I regularly backup all the catalogue locally and off line. I noticed that rather than about 6Gb this jumped to over 10GB off line . When I looked at the program data in local, IDimager there were a lot less odd folders and individuals files than there were in the backup folder. As I had backups I deleted the backup data and re saved the backup. Many of the original deleted items were not recreated and the size dropped to just over 6Gb again. But in the program data folder there are some which aren’t being backed up, EditorSchemas (this is empty) , Catalog (this has over 6Gb data) and ImportProfiles (this has 4k).
I have two queries, have changes to the catalogue changed the structure of the form the date is kept in (if so it would be useful to be warned you needed to clear out the unused old data) and should the non-saved folder be being backed up or is the data being saved in a different format?
