What can I do with:"Error while converting RAW file. (-2) (0)"
emha
Post by emha » 25 Nov 20 17:46
I have a Database of around 100.000 photographs. All works fine, but some RAW files generate that error.
In Capture One I can edit these files without any problem.
I run PS on a Mac (Big Sur) an the RAW is from a Fuji GFX 50R.
Is this a known issue?
vkfoto
Re: What can I do with:"Error while converting RAW file. (-2) (0)"
Post by vkfoto » 25 Nov 20 19:01
What kind of raw file made by what camera? If the camera - lens combination is not supported by DXO I don't think it can process the resulting files.
I have some old CRW files from 2004 made by a Canon S30 that can't be processed
OOPS, didn't notice the named camera. Is it supported?
emha
Post by emha » 25 Nov 20 19:14
Yes
P.S. Bist Du der Volker?
Post by Hert » 26 Nov 20 9:46
I just downloaded some sample RAF files for the GPF 50R and they display fine in PSU. You mention "some RAW files"
If possible, can you send me such a file so I can check it here? You can send it as an email attachment to support@idimager.com or upload it to some cloud drive (oneDrive, iCloud, Google Drive, DropBox, WeTransfer, etc) and send a download link to the mentioned email address.
t.i.a.
emha
Post by emha » 26 Nov 20 17:30
Thank you, i will do later this evening.
emha
Post by emha » 26 Nov 20 21:34
Hert wrote:
26 Nov 20 9:46
If possible, can you send me such a file so I can check it here? You can send it as an email attachment to support@idimager.com ...
Okay, I've sent you an email.
Post by Hert » 27 Nov 20 1:14
Thank you for the sample file. The next build will have this fixed.
emha
Post by emha » 27 Nov 20 7:23
Hert wrote:
27 Nov 20 1:14
Great. Thank you.
emha
Post by emha » 03 Dec 20 7:56
Hert wrote:
27 Nov 20 1:14
With the build 3317 it works. Thank you very much again.
Post by Hert » 03 Dec 20 9:02
Great! Thank you for the feedback
vkfoto
Post by vkfoto » 22 Dec 20 21:43
I found three examples of this error in some of my 2006 raw files made by a Canon PowerShot S30. The other RAW files in the set don't have this issue.
Error while converting RAW file (-2)(0).JPG (104.03 KiB) Viewed 711 times
The ree file have been zipped and sent to support
Post by Hert » 24 Dec 20 0:08
For some reason, none of your emails reach me.
Best to upload files to your own cloud drive (DropBox. WeTransfer, iCloud, OneDrive, Google Drive, etc) and send me a download link. PSU uses the latest LibRAW to convert CRW files and your error is raised when LibRAW fails to convert a file. As LibRAW can't read them then these are most likely corrupt files.
