Cloud Vision API error
Post by Mke » 24 Jun 20 18:55
Although I'm not attempting to use AI for labeling, I am very occasionally getting the error message below while manually labeling.
Presumably this shouldn't be happening.
Re: Cloud Vision API error
Post by Hert » 24 Jun 20 20:37
PSU only does AI labeling when triggered by the user.
Perhaps you clicked on Detect Labels In the LAP? Or used a shortcut that is assigned to AI labeling (see shortcuts manual)? Could also be that you have AI labeling switched on in the import profile?
Post by Mke » 24 Jun 20 23:28
No, none of those apply. I'll report back if I can identify any specific trigger.
Post by Mke » 11 Mar 21 0:15
It's take a while, but I just had this happen again.
After working in another application, I returned to PSU and, with an image in the preview window, clicked on the search box in the LAP and starting typing to assign a label (starting with a W). PSU became non-responsive for a few moments, then returned with the image I was working on flipped through 90° and with the Cloud Vision API error message over the top of it. Strange.
Post by Hert » 11 Mar 21 0:22
Hmm, these are the AI shortcuts (using Vision) that are active when the preview Windows is open:
I expect that you hit one of those. However, I don't expect those shortcuts to be functional when you are in a text box (like the search box)
Post by Mke » 17 Mar 21 17:16
I just had a similar experience. Strangely, the cursor seemed to be at least partially active in two places at once, which might point to a cause? Specifically:
1) If I typed in the the top-right search bar, my typing didn't appear, but the Cloud Vision warning popped up when I hit the return key. It did this reliably, each time I repeated it.
2) If I typed in the LAP box to assign a label, this appeared to work normally, however the cursor remained flashing in the top-right search bar.
3) If I repeated step 1 above, the Cloud Vision warning still popped up.
Thought I'd caught it all on video, but I only got a small clip without the warning, showing only the 2nd case. Here's a screenshot:
