Selecting batch "Output folder"
User avatar
Post by G8DHE » 05 Feb 20 11:36
Does anyone else suffer a problem in making a selection of a new output folder when opening a batch window ?
I've noticed that it seems impossible to select a new folder, unless its the very first operation on opening the window and even then it occasionally needs the window closing and re-opening before the selection either appears in the displayed output folder or is displayed in the recently used list where it can then be selected.
I have reported this on Mantis https://mantis.idimager.com/view.php?id=3358 and it first occured / noticed with version 4 but is still happening for me on version 5.
Is this specific to me ? I have noticed on both my main workstation and my laptop so it would appear to be common and not machine specific ?
User avatar
Re: Selecting batch "Output folder"
Post by G8DHE » 12 Feb 20 12:10
Yea yes 2709 has fixed the problem. Thanks Hert.
