Working with additional apps/ Making the catalogue available to mobile usage
Connor
Post by Connor » 10 Nov 19 14:01
Dear,
are there any experiences for working with other apps - specifically those to make either the catalogue or the files including metadata available to mobile clients?
The idea behind that question ist to have a workflow that enables me to check the phots inside the database and to rate, approve or decline them.
From further finding, I think that Neofinder could be a valid idea for that - are there any experiences or recommendations into that?
Thank you in advance,
best regards,
Connor
User avatar
Re: Working with additional apps/ Making the catalogue available to mobile usage
Post by G8DHE » 10 Nov 19 14:34
If the database is on or can be copied to the mobile device then "Travel Mode" is what you want.
This is what I do when out with the Laptop this means I have access to all the Metadata and Thumbnails under the main database.
Connor
Post by Connor » 10 Nov 19 15:00
G8DHE wrote:
10 Nov 19 14:34
Thank you for your suggestion - from what I understood is that the "Travel Mode" is rather something that I would use on a system where I can install Photo Supreme on. When mentioning "mobile", I was rather thinking towards an iPad or even a phone.
Would that also be a possibility?
User avatar
Post by G8DHE » 10 Nov 19 19:49
No there isn't any API to the single user version, if I need to work on the full database then I just VNC into the workstation at home and run the normal interface that can be from a Phone, Laptop or whatever you just need a VNC app for the device your using remote.
