On close application, you're asked to close all tabs
KeesdH
Post by KeesdH » 08 Nov 19 10:52
Hi all,
I accidently switched on "close all tabs" and "do not ask anymore" when closing v5.
Looked in all menu's and the help files but could not find how to turn this back on.
Also the "revert all do not ask anymore questions" in the help menu did not work.
Thanks for your help
Re: On close application, you're asked to close all tabs
Post by weidmic » 08 Nov 19 15:17
If you need to reverse this setting now, then there is a setting in the registry you could give a try...
I guess the value needs to be set to "0"
Warning: Changing registry settings is on your own risk
Anmerkung 2019-11-08 151336.png (29.42 KiB) Viewed 810 times
KeesdH
Post by KeesdH » 09 Nov 19 11:13
Well I did close PSu two times while not getting the dialog after the revert do not ask..... After having to do a forced close (PSu does hang from time to time unfortunately) the dialog appeared again. Problem solved although not the way it should be.
