save and read Portfolio + Categories / Keywords
Ralf
Post by Ralf » 09 Oct 19 18:15
I use two databases, one for testing and one for my regular photos, so I have two directories (see below)
Is there a way to save the following data and read it into the other database? Creating a new manual job is often very time-consuming.
- Portfolio
- Categories / Keywords
or do I have to use the same Appdata directory?
Links of the two databases:
"C:\Program Files\IDimager Products\Photo Supreme 4\IDimagerSU.exe" -a "c:\Users\Ralf\AppData\Local\IDimager Systems, Inc\" -D E:\Fotos.cat.db"
"C:\Program Files\IDimager Products\Photo Supreme 4\IDimagerSU.exe" -a "c:\Users\Ralf\AppData\Local\IDimager Systems, Inc - Test\" -D E:\Testbilder\Test.cat.db"
Ralf
(Excuse my english)
Re: save and read Portfolio + Categories / Keywords
Post by Hert » 09 Oct 19 20:39
You can export/import the category structure to/from file.
https://repository.idimager.com/openres ... BA39394939
You could consider using ICS reading in the test database to get Portfolios in with the import of images.
Ralf
Post by Ralf » 10 Oct 19 18:20
thanks for the information, only leather not quite what I'm looking for, the script overwrites everything when importing. I would like to export the categories downwards from a certain point on and insert or read them in the other database at the cursor position.
Nor are the portfolios secured.
I have to search for it ;)
Ralf
(Excuse my english)
