I'm still testing iDimiger and my first question is: Can we write out metadata to XMP sidecar file only? We don't want to change JPG files themselves at all.
Ulrike
Write metadata to XMP sidecar, but not to image file
Re: Write metadata to XMP sidecar, but not to image file
The metadata standards defines that XMP must be written embedded for JPG.
You can configure psu to not write metadata. And there’s a batch command that allows you to save XMP to a sidecar file. The batch command is “Export XMP to File”
In addition to Hert's reply, if JPG files are made read-only (an option in the importer) then PSu will use a sidecar file on syncing.
There is nothing in the XMP standard that enforces writing metadata into JPEG. Our images a tagged in Cologne and only XMP sidecars are transferred to Einthoven and Hagen. Also backups only need to write changes in XMP but not 500 high resolution photos per day.
I had a look into the settings but I can see nothing that sets JPEG to read only. Could you please add some detail?
Hello, i have the same question. How to run batch command that allows you to save XMP to a sidecar file ?
Thank you so much
julien
Thank you so much
julien
- Select one or more thumbnails that you'd like to have its XMP exported for
- Click Batch in the lower command bar (below the thumbs)
- In a new batch, click the plus button
- Add "Export to XMP file
- Run the Batch
