could be changed the short to close ps from ctrl+shift+q to ctrl+q?
mantras
Post by mantras » 28 May 19 7:47
Hi
under windows , could be changed the shortcut from ctrl+shift+q to ctrl+q ?
to closed almost all program under windows ,the shortcut is ctrl+q (like macos )
thanks
Re: could be changed the short to close ps from ctrl+shift+q to ctrl+q?
Post by Hert » 30 May 19 9:20
Afaik the standard Windows shortcut to close an application is Alt+F4.
I tried it here with several applications (including different Microsoft Office applications) and none of them respond to Ctrl+Q. All do respond to Alt+F4.
mantras
Post by mantras » 02 Jun 19 18:53
Hert wrote:
30 May 19 9:20
hi
well , for example photoshop ,bridge,lightroom even audition cc , ptgui pro , all of them and others have ctrl+Q to close the application
it was just an idea but alt+F4 works with all
thanks
