Version set down arrow not appearing
peterpix
Post by peterpix » 19 Apr 19 18:05
For some reason the down arrow to scroll down through tabs for versions beyond version 6 is missing. I think it might be hiding behind the version 6 tag, as I can just see a bit of the down arrow, but can't click it.
I'm attaching an example of a version set which has 9 versions, but only 6 tags are showing and there is no down arrow (or just the edges, that I can't click).
This is happening now for all of my version sets. Previously the arrow was below the last version tag that was visible, so I could click it and the tabs would scroll, so I could access higher tags.
Is there a setting that can be used to correct this?
Peter
User avatar
Re: Version set down arrow not appearing
Post by G8DHE » 20 Apr 19 20:39
Muhh I think i might be suffering this as well!
Post by jstartin » 21 Apr 19 15:14
Here too, with 2032 on Windows. With careful examination just the very tip of the arrow is visible/available at the bottom right of the tab for version 6 with the view at 100%. Actually clicking in the right place is very hit and miss but can work (got it just once after much trying). Expanding to 300% gives a usable arrow but other display weirdness which vanishes after clicking the arrow.
I think this is a bug that should be reported on Mantis.
User avatar
Post by G8DHE » 21 Apr 19 15:54
peterpix
Post by peterpix » 21 Apr 19 16:58
g8dhe you beat me to it but I didn't know as we posted bug reports almost simultaneouly, so now there are two bug reports. Oh well!
Post by Hert » 22 Apr 19 14:21
You can download build 2077 from the website now (no web update signal). Install it over your existing version. Please let me know if that fixed this. Thank you
peterpix
Post by peterpix » 22 Apr 19 15:10
Hert, thanks.
Not sure what to download - the trial?
Peter
peterpix
Post by peterpix » 22 Apr 19 15:25
If it's the trial, I had a look at it (began to run the installer) and it's not clear whether it has the facility to install to a drive other than the default, which I assume is C. My current installation is on my D drive (as my C drive SSD is perilously full). I didn't dare click Install in case it just installed and was the wrong version. Does if offer the ability to install on a different drive after you click install? If not should I uninstall the current installation from the D drive?
Peter
User avatar
Post by G8DHE » 22 Apr 19 18:05
Yes, thanks working here fine.
peterpix
Post by peterpix » 22 Apr 19 18:47
Geoff, where did you get your installer from?
Peter
Post by Hert » 22 Apr 19 19:39
There’s only one installer. Download it from the website or, if you’re a licensed user, from https://cp.idimager.com (same link as that from the website) and install it over your existing copy.
peterpix
Post by peterpix » 22 Apr 19 19:47
Geoff, I didn't know where to log in, so thanks for that link.
Hert, like Geoff this works for me. Nice to get my full versions back.
Peter
Post by jstartin » 22 Apr 19 21:51
The arrow problem is fixed for a 100% view. At other view magnifications various odd things happen to the tabs, sometimes obscuring the arrow again. I suppose a new mantis entry is in order.
