Database disk image is malformed (0)
fsalveson
Post by fsalveson » 14 Apr 19 17:00
I've read what I found regarding malformed database issue and tried a restore of a relatively recent database backup. The same popup populated indicating a database disk image malformation, but it dead-ended there and wouldn't restore. What's next?
Franklin Salveson
Iptc4xmpCore_CiAdrCtry.txt
(12 Bytes) Downloaded 36 times
Iptc4xmpCore_CiAdrCity.txt
(50 Bytes) Downloaded 31 times
Flip R90.idrcp
(1.62 KiB) Downloaded 32 times
270 degrees.idrcp
(63 Bytes) Downloaded 33 times
copy of the message I receive
PS database corruption 2019-04-14.JPG (65.79 KiB) Viewed 489 times
Re: Database disk image is malformed (0)
Post by Hert » 14 Apr 19 19:12
Is your database on an internal hard drive? Did you have power outage recently.
Either way, you can always manually copy the two catalog files from the backup to the catalog folder. Then start psu. Compact afterwards
