Ordering labels within categories
peterpix
Post by peterpix » 08 Apr 19 11:27
It's possible to move categories up and down using the Move Up and Move Down commands in the context menu, but the same does not seem to apply to label order within categories. They just self-sort in alphabetical order. Is there a way to custom sort a set of labels, i.e. not alphabetically but manually determining the order?
Peter
Re: Ordering labels within categories
Post by Hert » 08 Apr 19 12:59
Unfortunately that is not possible. The labels always list alphabetically. Can you explain why it would benefit you if you could sort them manually?
Right now, the only way to achieve a manual order is by adding a prefix to the name. But that’s far from ideal.
peterpix
Post by peterpix » 08 Apr 19 13:07
Hert thanks
The benefit would be that some items are more important than others. I guess I can adjust the heirarchy if necessary.
