Question about Rename
User avatar
OldRadioGuy
Post by OldRadioGuy » 16 Mar 19 18:47
Is Photo Supreme supposed to rename sidecar files when images are renamed?
I just did a test in a folder with a few images that had .xmp and .on1 sidecars, selecting the images, and then right-clicking to navigate to Rename.
Only the images were renamed. Neither of the sidecar formats was changed.
Thanks in advance for your information.
macOS High Sierra; 27-inch iMac, Retina 5K; Photo Supreme 4; DxO PhotoLab 2; ON1 Photo RAW 2019; Alien Skin ExposureX4; Affinity Photo 1.6.7; PhotoLine
Re: Question about Rename
Post by Hert » 16 Mar 19 20:56
Photo Supreme will rename supported sidecar files. XMP is a supported sidecar file for RAW files, so renaming a RAW file also renames its XMP file.
