Rename catalogue
Rhod
Rename catalogue
Post by Rhod » 03 Mar 19 23:09
Probably an elementary question but I would like to rename my main catalogue. Is it simple? Thanks.
Re: Rename catalogue
Post by Hert » 04 Mar 19 12:17
1. Enable the login dialog in the Preferences (General)
2. Close PSU
3. Start PSU and check the location of the catalog files in the login dialog
4. Cancel login
5. Open the catalog folder
6. Rename the files:
photosupreme.cat.db and photosupreme.thumbs.db in your Catalog folder to something else (keep the extensions cat.db and thumbs.db)
7. Start PSU
8. Select the new catalog name from the drop down
9. Disable the login dialog again
Rhod
Post by Rhod » 04 Mar 19 21:26
Thanks Hert!
