closed: Event name variable is not resolved again - rename files
Ralf
Post by Ralf » 22 Feb 19 14:28
in the screenshot you can see which way I went.
the similar problem is in Mantis ID 0003331 https://mantis.idimager.com/view.php?id=3331
and here the new Problem Ticket https://mantis.idimager.com/view.php?id=3348
First, mark Picture and open the Menü - File rename
01.rename file.jpg (108.38 KiB) Viewed 1005 times
no matter which form I take, here with Script
02.with scriptcode.jpg (22.39 KiB) Viewed 1005 times
03.the scriptcode.jpg (5.99 KiB) Viewed 1005 times
or here with the variable directly
04.with Eventname.jpg (32.17 KiB) Viewed 1005 times
the result is always the same wrong
05.false result.jpg (4.36 KiB) Viewed 1005 times
Ralf
(Excuse my english)
Re: Event name variable is not resolved again - rename files
Post by Hert » 22 Feb 19 16:23
:) Event Name is a field that one can enter in the Import Module, hence only rename rules in the Import Module can use %EventName which maps to the value that you enter in the Import Module.
If you want to use the event name as currently written in the metadata then use the that metadata field; that would typically be %xmp:Iptc4xmpExt:Event
Ralf
Post by Ralf » 22 Feb 19 16:32
yes, I took the rename, I thought that goes there too. Too bad that is not the case.
For me are after a holiday, all the pictures in a folder, from there I lwollte on the rename (as in the import), the selected pictures in individual days / topics move instead of these individually create and move manually.
Thank you for your help :wink:
Ralf
(Excuse my english)
