[resolved] Backup problems PostgreSQL 10
Username
Post by Username » 22 Jan 19 0:01
I've run into problems backing up my Postgres 10 DB.
It appears that I have problems with PSu Server builds newer then 1723. I can not get any of them to create a backup properly.
All earlier pg builds works perfect.
Both backing up and restoring properly.
I've filed a mantis for this.
- I'm the user
gcurrie
Re: [resolved] Backup problems PostgreSQL 10
Post by gcurrie » 11 Feb 19 22:21
Any possibility you could tell us all and help someone avoid a similar situation?
Gordon Currie
Photo Supreme 4.3 PostgreSQL on Windows Server Essentials 2016
Username
Post by Username » 12 Feb 19 7:08
Hello
It was a problem I ran into which was caused by a bug in PSu way of using pg_dump I believe.
Hert fixed it in build 1901.
I did not have to do anything else other then upgrade the client side of PSu Postgres version and initiate a backup.
That ran perfect.
- I'm the user
rdv4rjm
Post by rdv4rjm » 14 Feb 19 9:19
It is working for me as well.
Hadn't been able to do a backup from within PSU since November.
Now it is running fine.
Thanks Hert!
