solved: ImportDialog EventName is not working properly
Ralf
Post by Ralf » 21 Jan 19 15:03
With the version .1911 it works now, exactly as it should be - thanks
Unfortunately I found another mistake.
In the Import dialog, I put in the custom fields EventName and save the profile. After doing everything is fine.
01-Import Dialog.jpg (32.91 KiB) Viewed 983 times
03-EventName no Textfield.jpg (7.23 KiB) Viewed 983 times
With the second import I load the attitudes and the field EventName is there no longer a variable with% Zeichen but a text field.
02-EventName Textfield.jpg (4.35 KiB) Viewed 983 times
also a new change and absprezer brings the same result
greeting
  Ralf
Ralf
(Excuse my english)
Ralf
Re: ImportDialog EventName is not working properly
Post by Ralf » 22 Jan 19 18:05
I have to annoy again, maybe someone has a Woraround for me or someone can say that this is a mistake.
If so, you can report that somewhere or this is enough in the forum.
Because without it is really tedious to import so many photos into the catalog and adjust each process manually. The waiting time of the program takes a long time.
Thank you for your patience
greeting
  Ralf
Ralf
(Excuse my english)
Post by Hert » 23 Jan 19 14:43
Did you already file a ticket in Mantis for this? And don't forget to include steps to reproduce it there (in what field are you using %EventName, when does it change to T EventName). Thank you
Ralf
Post by Ralf » 23 Jan 19 14:51
No I have not, have just seen about other posts that there is. I'll try that
Ralf
(Excuse my english)
Post by Stephen » 24 Jan 19 0:40
Ralf, you should do another test. I had something similar recently using V3. I just tried again and it looked like the mistake was going to reoccur, but it didn't.
I first selected the import profile I wanted. Then I clicked on Custom defined (at bottom) to verify the commands and indeed %EventName had changed to T EventName.
Photo SupremeScreenSnapz193.jpg (200.54 KiB) Viewed 894 times
However, when I proceeded to import the test file I was prompted for an event name and the import functioned correctly. That is why I say you should verify.
Why the command line has changed I cannot answer.
Photo SupremeScreenSnapz194.jpg (92.97 KiB) Viewed 894 times
sanphotgn
Post by sanphotgn » 24 Jan 19 3:44
I tested this, again, today. I chose a file name based on Event Name. I looked at the Custom defined to see if Event Name was %EventName or T EventName. It was T EventName. So, choosing one of the defaults that includes Event Name, creates T EventName.
I can't help but think this needs to be enabled:
I saved the profile. Closed out PSU. Opened it. Used the same profile and it worked.
Ralf
Post by Ralf » 24 Jan 19 11:22
I did it the same way and after reopening PSU was the same error, he asks for the EventName, but does not write the content but the name EventName.
About Mantis I have just got the info the latest update 9.11 from the website to load and try out.
I will do that as well as I find the link;)
Ralf
(Excuse my english)
