google maps gives script error
bimo
Post by bimo » 16 Jan 19 18:31
I'm on PostgreSQl 4.3.2.1857 and I can geocode as well as doing reverse geocoding, but: google maps doesn't show up. Instead I get a popup window claiming a sript error did occur (see sreenshot).
Anyone any idea what is wrong? Any suggestion what to do?
Help is very much appreciated...
[edit Hert; changed title to better match topic]
google_maps-script error.jpg (20.56 KiB) Viewed 549 times
Re: google maps again
Post by Hert » 16 Jan 19 22:16
Already tried to restart PSU?
And after clicking to continue the script, can you then work with the map?
bimo
Post by bimo » 16 Jan 19 23:58
After restart the map's window behaves the same: it doesn't appear but the msg pop up does.
Clicking to continue: the error msg shows up 7 times and then the map's window remains empty.
Post by Hert » 17 Jan 19 0:31
Please try to reinstall PSU
bimo
Post by bimo » 24 Jan 19 10:50
Hert, thanks for your advice. Now running PostgreSQL server 4.3.2.1901 and the above popup has never been seen again...
BUT: nearly every time I start the GEO-Tag panel I now get the following pop up
google_maps-script error2.jpg (20.2 KiB) Viewed 451 times
Any ideas for that as well?
Re: google maps gives script error
Post by Hert » 24 Jan 19 13:50
Some ideas;
1. What Windows version are you using? Make sure you're up-to-date
2. Do you have Internet Explorer 11 installed?
3. Check that you have Javascript enabled in Internet Explorer (not to be confused with Edge)?
4. Did you install PSU in the same user account that you're running PSU in?
