Computer Wiped...Now What?
cardio1
Re: Computer Wiped...Now What?
Post by cardio1 » 15 Feb 19 1:37
I'm afraid your questions are above my computer knowledge Hert.
I did enable ICS reading when I installed postgres.
I don't know how to check with a metadata tool
The catalog I used were names I developed over the years: Mom, Dad, Vacation etc. Not private really.
Is there no way to "restore" like we used to when we lost a database?
What is wierd is the small 10 pictures I did first had the catalog labels, but the big import did not.
Post by Hert » 15 Feb 19 8:46
cardio1 wrote:
15 Feb 19 1:37
You have Photo Supreme ;)
1. Right click on a thumb
2. Select Run Script from Repository
3. Select Metadata -> Full Exif Dump
cardio1
Post by cardio1 » 15 Feb 19 23:58
Keywords are there!
But not being imported
I did do ICS thing when I start Prosgrel.
Is there a way to check to be sure it is working?
Ralph
Screen Shot 02-15-19 at 04.55 PM.JPG (1006.59 KiB) Viewed 3213 times
Post by Hert » 16 Feb 19 8:20
That is IPTC keywords, you were going to check if ICS is in the metadata.
But if ICS is not there and IPTC keywords is all you have, then you can always import the IPTC (Metadata - Convert Metadata to XMP from context menu).
andrew.heard
Post by andrew.heard » 17 Feb 19 1:23
Hert wrote:
15 Feb 19 8:46
cardio1 wrote:
15 Feb 19 1:37
Why would I not see thumb context menu > Run Script from Repository? Am running 4.3.2.1927. I haven't had a need to Run Repository Scripts before now but I know it's been implemented for far earlier PSu versions. Thanks for help.
Post by Hert » 17 Feb 19 7:53
It won’t be displayed if one of these items applies;
1. The OS tells PSU that you’re not connected to the internet,
2. Your firewall blocks PSU from accessing the internet
3. You disabled the repository in Preferences-Other settings.
cardio1
Post by cardio1 » 10 Mar 19 17:38
Hert,
Been out of town working.
Attached is screen shot
Xmp says yes
Still no catalog labels
Ralph
Screen Shot 03-10-19 at 11.37 AM.JPG (1004.19 KiB) Viewed 3085 times
Post by Hert » 10 Mar 19 17:46
Ah IPTC-IIM (classic) keywords only. The software that you use on your image files must also write keywords to XMP when XMP is present. Apparently you used a tool that doesn't do that and only writes IPTC-IIM. Probably an outdated tool.
PSU allows you to re-convert metadata back to XMP to help you fix such omissions created by 3rd party tools.
Right click on a select thumb and select Metadata -> Convert Metadata to XMP
cardio1
Post by cardio1 » 11 Mar 19 19:08
Hert,
The ONLY tool I've ever used to assign labels to my pictures is PSU within the program itself. Never anything else.
cardio1
Post by cardio1 » 11 Mar 19 19:17
Hert,
Converting metadat to xmp did not change the catalog labels in any way. :(
Post by Hert » 11 Mar 19 19:59
There’s a save button in the full EXIF dump. Can you paste that here, because your screenshot doesn’t show everything.
If these are written with PSU then there is XMP.
If there are keywords and they don’t roll in then your Sync Readsettings are also relevant. Also post a screenshot of fhat
cardio1
Post by cardio1 » 17 Mar 19 22:02
exif dump text file attached
I don't understand about your second question "sync readsettings" screen shot. Not sure what/where that is. Will need more direction please.
exifdump.txt
(6.79 KiB) Downloaded 195 times
Post by Hert » 18 Mar 19 7:47
Open Preferences
Open Synchronize Settings
Open Tab Read Settings
cardio1
Post by cardio1 » 19 Mar 19 0:09
Screen Shot 03-18-19 at 06.07 PM.JPG (977.74 KiB) Viewed 2948 times
ok found it screen shot attached
is the setting for "merge keywords" correct too?
Post by Hert » 19 Mar 19 7:09
With these read settings and with that metadata in the file, the keywords Christmas and Erin must show up when you right click on the thumb-Metadata-Read metadata from file
