Backup fails PSU quits
rdv4rjm
Post by rdv4rjm » 11 Dec 18 5:28
Had major modification to do in folders structure and in Catalog Categories.
Once done I wanted to backup the catalog.
PSU hangs. Coloured circle appears. I let it as is overnight.
Next morning PSU is closed.
Disk free space: 885gb
I also upgraded to last version.
Would anyone have suggestions?
Thanks in advance
Re: Backup fails PSU quits
Post by Hert » 11 Dec 18 11:03
Are you using Single or Server edition? If the latter, what database system?
rdv4rjm
Post by rdv4rjm » 11 Dec 18 15:26
I am using Server Edition
Postgres on Mac
Post by Hert » 12 Dec 18 14:31
How large is the backup file?
Btw. On postgresql you can always backup with the pg tools; eg pg_dumo or from witching pgAdmin. Those will be a multitude faster to use as backup.
rdv4rjm
Post by rdv4rjm » 16 Jan 19 7:41
Finally got to it yesterday.
I tried pg tools, got errors.
Used pgdump command, worked ok.
Used pg_dumd; file was 380mb.
With pg_dumpall, file was 6.2 gb.
In a disaster scenario where I would loose my whole database, which version would be best to use to restore entire database?
Today, I tried PgAdmin 4.
New version is Web based.
First try, file was 99mb.
Second try I choose options, to the best of my understanding, options referring to data and tables. File increase to 700mb.
I then ran pg_dumpall: 13gb.
I may be storing useless information.
Would like to know best backup method.
If anyone would have a script for backing up automatically, I would sure appreciate it.
Post by Hert » 16 Jan 19 9:21
At minimum backup the photosupreme database (using pg_dump or pgAdmin).
The thumbs can always be rebuilt if needed. Backing up the thumbs database as well could be convenient and save time to get up and running when a restore is needed.
