star rating script - update?
Post by weidmic » 30 Nov 18 18:04
Hert,
you have been so nice to provide a script for the star rating for the custom thumb info.
Now that you have introduced the support for a 'reject' rating, I would love to see the script updated :wink:
%code
    var
      ACatItem: TCatalogItem;
      ARatingAnchorHref: String;
      ARatingNoColor: String;
      ARatingColor: String;
      ARatingStar: String;
      ARatingOnStar: String;
      ARatingOffStar: String;
      i: Integer;
    begin
      result := '';
      ARatingNoColor := '#CFFF0000'; //#### red color
      ARatingColor   := '#CFFFFF00'; //#### Yellow color for rating stars
      ARatingStar    := 'M 3.03,4.19883 L 2.996,4.22354 L 3.00909,4.26369 L 2.97501,4.2389 L 2.94086,4.26369 L 2.95394,4.22354 L 2.92,4.19883 L 2.96193,4.19883 L 2.97501,4.1589 L 2.98801,4.19883 L 3.03,4.19883 Z ';
      ARatingAnchorHref := 'code:' +
'  function IsImageItemSelected: Boolean; ' +
'  var ' +
'    i: Integer; ' +
'  begin ' +
'    result := False; ' +
'    for i := 0 to Selected.Count - 1 do ' +
'    begin ' +
'       if Selected.Items[i].GUID = ImageItem.GUID then ' +
'       begin ' +
'         result := True; ' +
'         exit; ' +
'       end; ' +
'     end; ' +
'  end; ' +
'var ' +
'  i: Integer; ' +
'  ACatItem: TCatalogItem; ' +
'begin ' +
'  if not IsImageItemSelected then ' +
'  begin ' +
'    Selected.Clear; ' +
'    Selected.Add(ImageItem); ' +
'  end; ' +
'  begin ' +
'     ACatItem := TCatalogItem.Create(nil); ' +
'     if PublicCatalog.FindItemCombinedByGUID(Selected.Items[i].GUID, ACatItem) then ' +
'     begin ' +
'       ACatItem.Rating := #rating#; ' +
'       if PublicCatalog.StoreItemToDataBase(ACatItem, False) then ' +
'         PublicCatalog.UpdateItemSyncState(ACatItem, [], [idcsDBXmp], False, True); ' +
'     end; ' +
'     ACatItem.Free; ' +
'  end; ' +
'end; ' +
      ARatingNoOnStar   := '<a href="' + ARatingAnchorHref + '"><img title="no rating" size="22" path="' + ARatingStar + '" pathfillcolor="' + ARatingNoColor + '" pathstrokestyle="solid" pathstrokecolor="' + ARatingNoColor + '"></a>';
      ARatingNoOffStar  := '<a href="' + ARatingAnchorHref + '"><img size="22" path="' + ARatingStar + '" pathfillstyle="none" pathstrokestyle="solid" pathstrokecolor="' + ARatingNoColor  + '"></a>';
      ARatingOnStar     := '<a href="' + ARatingAnchorHref + '"><img size="22" path="' + ARatingStar + '" pathfillcolor="' + ARatingColor + '" pathstrokestyle="solid" pathstrokecolor="' + ARatingColor + '"></a>';
      ARatingOffStar    := '<a href="' + ARatingAnchorHref + '"><img size="22" path="' + ARatingStar + '" pathfillstyle="none" pathstrokestyle="solid" pathstrokecolor="' + ARatingColor + '"></a>';
      if Catalog.FindImageCombined (ImageItem, ACatItem, False, vptNone) then
      begin
        result := result + '<font color="'+ ARatingColor +'"><ind y="2">';
        if ACatItem.Rating > 0 then
          result := result + StrTran(ARatingNoOnStar, '#rating#', '0');
        else
          result := result + StrTran(ARatingNoOffStar, '#rating#', '0');
        for i := 1 to ACatItem.Rating do
          result := result + StrTran(ARatingOnStar, '#rating#', IntToStr(i));
        for i := ACatItem.Rating + 1 to 5 do
          result := result + StrTran(ARatingOffStar, '#rating#', IntToStr(i));
        result := result + '</ind></font>';
      end;
      ACatItem.Free;
    end;
    %/code
<a href="code:
var
  AItem: TCatalogItem;
begin
  AItem := TCatalogItem.Create(nil);
  try
    if PublicCatalog.FindItemCombinedByGUID(ImageItem.GUID, AItem) then
    begin
      PublicCatalog.WriteItemToXMPAdvanced(AItem, PublicOptions.XMPSyncWriteSettings, True, PublicOptions.XMPSyncWriteSettings.StoreCached);
    end;
  finally
    AItem.Free
  end;
end;"><FONT color="#FF0000">Save</a>
If you don't mind, I would like to ask you to update the script in order to reflect the reject rating.
Best Regards,
Re: star rating script - update?
Post by Hert » 01 Dec 18 9:25
I've updated the version of the script in the repository. With Custom Thumbs, use the drop down in the line -> From Repository -> Functional Rating Bar
Apparently you were using a customized version of the script. You should add that "Save" option that you've added at some point
Post by weidmic » 03 Dec 18 13:53
Thank you! Much appreciated...
Larry56
Post by Larry56 » 03 Dec 18 18:07
I like the ability to change all stars at once with the red star in the old script. I thought I could customize the new one with reject option but this looks way too complicated for me.
Can anyone tell me which part of the old script I can copy and past into the new? Or does it have to be a whole new script?
Post by Hert » 04 Dec 18 8:29
The red icon was to revoke a rating. Now you should click the active rating to remove it again.
e.g. a 3 star rated image. Click the 3 star rating to revoke the rating
Larry56
Post by Larry56 » 04 Dec 18 17:37
Thank you.
