how to copy path and filename
Post by snowman1 » 29 Oct 18 22:37
Anyone know of a quick way to copy an image's file path and file name? I can't see anything on the right-click menu? And that field in the info panel is not copyable.
Snowman1
sanphotgn
Re: how to copy path and filename
Post by sanphotgn » 29 Oct 18 23:16
This may not be as quick as you would like, but it does work.
Go to the Info panel, create a Custom Field - Add Macro Field. Add the fields you want.
My Macro Text looks like this:
%FilePath\%FileName
When you want to copy, make sure you choose Select All, then Copy.
User avatar
Post by G8DHE » 29 Oct 18 23:53
In current versions here is how to do it;
Post by snowman1 » 30 Oct 18 1:25
Thanks guys. Geoff, that's exactly what I want, cheers!
Snowman1
tumirnix
Post by tumirnix » 17 Jan 19 22:22
there is a second way hidden in the context menu, that you can copy the folder and file names of selected files.
In German it's "Starte Skript vom Repository" > "Files System" > "Copy Filename to Clipboard".
As you can see, only the first part of the menu has been translated.
Best regards
Martin
Post by snowman1 » 18 Jan 19 1:34
Hi tumirnix
I think that is what Geoff has posted.
Snowman1
tumirnix
Post by tumirnix » 19 Jan 19 20:58
That's interesting, in the posting by Geoff (G8DHE) I see (using Firefox) only the word "Image", not the image itself.
So I checked it again with Chrome and there is indeed the screenshot with the opened menu.
Sorry for the confusion
Martin
Post by snowman1 » 19 Jan 19 22:42
No worries and thanks for helping, it's what this great forum is all about. Strange about the browsers though - I use FF myself, I have Ghostery and NoScript installed on and other security settings so I sometimes don't see some images etc myself but I can confirm that I did see Geoff's screenshot using FF.
Snowman1
