How to select all photos with a given star rating
barneagle
Post by barneagle » 19 Aug 18 17:38
Sorry if this is a dumb question.
I know that if I have a selection of photos in the main window (selected by date, or category, or search results, or whatever) I can filter it by star rating. However, I can't see how to get all photos in the main window so that I can see, for example, all my 5-star photos. Help, please!
Re: How to select all photos with a given star rating
Post by Stephen » 19 Aug 18 17:52
If I don't misunderstand you, it's possible to click on the filter top left of the main window.
Unless you mean that your main window is your whole library? I cannot do that because a Mac will only display 25,000 images at one time. SO I cannot test, but the same principle might work. You could then save that setting and mark it as a favourite.
User avatar
Post by G8DHE » 19 Aug 18 22:26
If you select the Ratings, either from the top tabs or from the All listing then select the Star rating required ?
Post by Hert » 20 Aug 18 5:18
Stephen wrote:
19 Aug 18 17:52
FWIW; That 25K display limit on macOS was removed with the 4.1 release (the 64 bit release).
barneagle
Post by barneagle » 20 Aug 18 8:50
Sorry! I missed the "By Rating" in the drop-down menu under Catalog. Thanks for the replies.
