Settings - ICS on/off and why?
Post by RobiWan » 04 Aug 18 16:45
PSU has in setting by sync settings - write/ read ICS schema.
What are the benefit or disadvantages of this setting? the XMP files are sometimes also written by other software
Re: Settings - ICS on/off and why?
Post by jstartin » 04 Aug 18 22:02
Some of the things that PSu can do, such as portfolios, are not covered by XMP standards. Writing the ICS schema while syncing to XMP allows the full catalog structure/content to be recovered by importing files into a new catalog without having to rely on a backup. Hert recommends that this setting is always on.
Reading the ICS schema is only necessary when recovering the catalog by importing previously synced files. Leaving this set to yes reduces performance in normal use, and Hert recommends leaving it off unless it is actually needed for disaster recovery.
Post by RobiWan » 04 Aug 18 22:45
Thanks for the explanation. I will think about turning it on. Maybe in the future but maybe not - I have always backup
