no geo coordinates found
After updating to the latest version 4.1.0.1402 the searching of geo coordinates given an place/address doesn't work anymore: it's saying no coordinates found! It's only by searching on the map to set the coordinates and this is very annoying.
Also when there is already geographical information attached to the picture (in the past geotagged pictures) it says there are no geo coordinates found for this place.
Re: no geo coordinates found
It does indeed in most cases not find any geo-coordinates for a location...
You might want to file a bug report in mantis
http://mantis.idimager.com/
PSUServer 6.x, PostgreSQL 12.x
Did you use a personal Google Maps API key? When google fails to accept the call, PSU will tell you that no coordinates are found.
I did...
Hert can you give a 2 examples that will find geo coordinates on your system? - with street and city
(and as I said in most cases it will not find)
I have nothing changed just updating. Up till now it was functioning well. Where can I see if I'm using such a key?
nikcob,
In 4.0.x there was no personal Google Maps API key - so if you havent set it, then you don't use one.
Just go to preferences - other settings - API settings
Here you can find more info about the API key:
https://developers.google.com/maps/docu ... -key?hl=de
Sure,
Here's something random that works;
Lat = 40.653557 north
Lon = 73.903656 west
Avenue D, New York
Here's another random coordinate;
Lat = 47.999573 north
Lon = 7.841800 west
Wentzingerstraße, Freiburg im Breisgau
Here's how to get a Google API key;
1. Visit https://console.developers.google.com/apis
2. On the left side, click Credentials
3. Click Create credentials -> API key (copy the key, you'll add that in PSU, but were' not there yet)
4. In the left menu, click Library
5. Search for: Google Maps Geocoding API
6. Open that box
7. Click Enable
6. Open that box
7. Click Enable
Hi HertHert wrote: ↑25 Apr 18 14:54Here's how to get a Google API key;
6. Open that box
7. Click Enable
thank you
@Hert:
The problem is the other way around:
For example search the coordinates for "Luik, boulevard de la constitution" and he will say no coordinates found.
When I have the coordinates, yes he will find the address data.
Niko
Niko
@Hert:
I have copied the key (there wasn't any there in the preferences) and enabled the box but the problem isn't solved by it.
@nikob; and @weidmic; I've uploaded build 1410 to the website (no webupdate trigger). This version fixes this. Can you confirm?
I can confirm this to be fixed...
Thanks!
Thanks!
@Hert/weidmic:
Do I have to download and install the trial version from the idimager site?
Yes
